Field PG with Graph 5?
Gwinnutt
Feb 2008
UK
Is anyone able to advise whether the last/latest version of Graph 5 will run on a recent generation Field PG on XP? Siemens no longer make Graph 5 available as a bundle option even if the machine is being ordered with both Step 5 and Step 7 installed. I have not supplied a PG with Graph 5 for several years now and believe the last machine I did install it on was a late Power PG running W98 or 2K with Step 5 as the primary package.
I have been able to source good used ex service dpt machines out of Germany in the past (but they too seem to be thin on the ground these days)so I may be looking to source a couple of good Field or Power PG's, depending on the answer to my question. Any suggestions?
Many thanks.
Many thanks. But why are Siemens not making Graph 5 available as part of a bundle set with a new PG which has Step 5 by special order? Each time I try to order a new PG with Step7 and 5 and Graph 5, Siemens send the order back saying that Graph 5 cannot be supplied as part of the order(??)
I am not sure why this is requested, but it was asked. Currently I have one PLC , with one output to a relay, turning on a field equipment (just...
240
Context: PLC= S7-1212C, HMI=KTP1200 Basic. Hi again, When the "REPORT" button is pressed (on a different screen), it takes the operator to the...
691
Looking for a LIDAR sensor (2d) that we can use with a Siemens PLC for measurement, Would like to interface directly with 4-20mA or a Field bus...
1,012
Hi Guys, I am doing a project that involves a Ring Configuration with 1756-EN2TR with Field Fiber Device 1783-ETAP2F and 1783-ETAP1F. I am not...
2,136
For Ethercat field IO-modules, like f.i. EP2308-0001 from Bechkhoff, you always have an Ethercat in connection and an Ethercat out connection, to...
897
