Fieldbus Failure in S7 300 PLC
deepak_kb
Nov 2010
bangalore
hi everybody im facing a unusual problem in s7 300 plc . when im using 1.5 mbps as baud rate in profibus network all the drives connected in the network shows healthy till i have not given the start command . But as soon i give it a start command the drive shows the fault of Fieldbus failure. and it happens everytime. But thats not the case with 187.5 kbps,its working fine with this baud rate.
i have checked the earthing of all drives & cpu network.
So please give any reason for this problem or any solutions??????
Problems I have faced in the past relate to either poor earthing or distance. You could try remaking off the ends of the cable. There is obviously some attenuation in the cable somewhere that you are getting away with at 187.5 but is causing problems at 1.5Mb...
Obviously, it is related to the noise that the drives generate.
You provide very little detail about your network.
Also, how long are the cables from the drives to the motors, are you using screened cables, etc. etc.
Anyone know of a cheap foundation fieldbus communicator? Something like the USB 8486 H1, but one that does not cost $3k? Thanks, Trevor EDIT: I...
135
Hello, Does anyone know how to export the EDD files for a device in DeltaV Explorer 12.3? I can export the .fhx, but I have no idea how to get...
141
Does anyone have any recommendations for Electronic Circuit Breakers with 0V Terminals built-in and Fieldbus (IO-LINK, MODBUS TCP, EtherNet/IP?)...
204
Hi all this is bit ot but here goes.. What kinda fieldbus you use / would use if youre going to build new installations on youre process.. Is...
24
4,347
Hello! First post here! Trying to commission a Danfoss FC302 frequency converter (with option A MCA121 EthernetIP-card) connected to ABB AC800M...
1,268
