File revision management?
GregPLC
Oct 2002
Milwaukee, WI
342
Does anyone know of a good way or good piece of software to help manage ladder files between laptops, desktops, and servers? The problem is knowing who has the most current version of a ladder file....any helpful hints to keeping these organized between techs.?
Thanks,
Greg
one simple solution is date the file each time its revised..ie programfile020300, programfile052301 etc. The first was modified or whatever on Feb 3, 2000, the second on May 23, 2001.
There can be issues when the machines were designed identical but addons vary when installed on location. I have many machines that were designed the same but changes over the years have made them different. When I run into this I may use the machine serial# in the program file name also.
If you open a RSlogix / Studio 5000 .ACD file with notepad, it shows a list of every "save" that has ever been performed on the file. A lot of my...
3,573
I have a project that has been ongoing for 6 years now. Constantly updating the program adding and removing components to the machine. Anyone ever...
1,575
When changing drawings and you update the revision in the title block such as rev 001 to rev 002 do most also indicate that is rev 2 in the file...
1,849
i need to know how to change ACD file RS LOGIX5000 from version 17 to 16.3 because my colleagues have change the original version from 16.3 to 17...
3,444
I have an Allen Bradley temperature switch that I am trying to use in studio 5000. I am getting the message "Unable to interpret the IODD file"...
85
