Filterind IP adress on 1761 NET ENI device
PACMAN
Apr 2004
HUY
Hello everybody,
I learn so much on this forum...
My question is : is there a way to filter incoming IP address on a net eni device ? in order to allow only wanted address ?
Thanks to all.
Vince
Where would the unwanted IP address be coming from?
Why would you want to filter it out? Is the increased traffic causing collisions?
Are you doing this for security reasons?
The reason why i'd like to do that is to give to the HMI's computers a kind of priority in interrogating a plc and let a limited access to the other computers (data loggers, or programming pc...).
Thanks for your answers ;-)
You have to use managed ethernet switch as DavidV suggested. The task of the switch - is to make a communication map and direct the traffic. Make sure IGMP snooping is turned ON
Hello everyone, I have a question... is it possible that two IPS in different network segments can see each other through communication between...
1,136
Hi, why i can't change output adresses ? And how can i do this ? In STAT i have output adresses starting from 4.0, but it is also not possible to...
1,203
Hi I need to find and IP of a drive profinet that bundown The machine doesn't have the IP and name of device write and anywhere It's a...
1,125
Hello, I´m using Codesys 2.3 and trying to access Wago I/O modules 750-430 and 750-530 by WORD variable (or maybe an array), unsure if it´s...
1,826
With RS5000 and a Clogix, I would like to know if i can work with same coils adresse on 2 different subroutine and just call one at the time? I...
3,200
