Simatic 300 - changing output adress
Caporeira
Jan 2023
On-Line
why i can't change output adresses ?
And how can i do this ?
In STAT i have output adresses starting from 4.0, but it is also not possible to change it.
2023-01-31 09_24_43-LAD_STL_FBD  - [FB2 -- _Traffic_Light_ -- ErsteProjekt_SIMATIC 300_CPU 317F-.png
As there are no outputs addressed at Q2.0 in your h/w config, remove all reference to them. The write to the addresses at Q4.0 etc replace the Q2.0 etc addresses on the outputs of your call to the FB
If you have symbolic address priority selected, you could simply change the symbol for "red" from Q2.0 to Q4.0 (and the similar for "orange" and "green"), and then save all the blocks. The addresses will be automatically updated.
Dear sir, I am using SIMATIC 300, CPU 315-2DP , (6ES7 315-2AF03-0AB0) VIPA 603-1CC21 A1.0 RAM 32KB, Firmware=V4.0.8 The problem Im using MPI...
170
Hi, I received this SIMATIC S7-300 training kit for maintenance. When I power it up, the PLC doesn't go to RUN mode and the STOP mode led is...
309
How can I integrate my S7-300 Simatic with the IFM AS-i Master AC1335 and its slave IOs, such as 2411 and Airbox 2041, into Simatic Manager?
119
Hello.We are trying to convert a program written with S7-300 Simatic Manager to S7-1200 V16.Unfortunately, there is only LAD,FBD option in S7-1200...
758
Hi to all, Our company does not usually use Siemens PLCs, but have a press with one in it. We are trying to change the IP address in our Simatic...
1,070
