Find Ip adress offline
Hojland
Oct 2006
Langå
203
Is there a way to find the ipadress in a logix 5000/ studio 5000 prg. Am havening a 1769-L16E and I can only see the ip adress in online state. in ofline it is greyedout
One thing you could try is a "Save As" of the program in XML format and save it as file type *.L5X
Then open the .L5X in a text editor and search for InternetProtocol and maybe it will show you the assigned IPAddress=xxx.xxx.xxx.xxx
(edit) This should also maybe work if saved as a L5K also
There is no IP under general tab.
I tryed to save it as a XML, and it worked. Thanks
But I am used to program in rslogix 500 and there you can easely find the ip.
Dont get it, why it has to be so hard in studio 5000
Thanks anyway
Have you tried saving it once connecting to it (as a normal .ACD)? It might sound a bit simplistic, but if the IP was added after the original file was downloaded to the controller, there will be no IP address to display in the saved file... Try saving it once you are online, then go offline and see if it shows up.
I have tryed to go online and "saved as", but when I go offline again, the internet protocol isgreyed out and no ip adress
Hi I need to find and IP of a drive profinet that bundown The machine doesn't have the IP and name of device write and anywhere It's a...
1,115
126
I have tested every screen and no single screen individually has this fault pop up, but when I compile and send to the PanelView it comes up. If I...
184
Hi, One of my customers has an old fabric tensile testing machine. The IC # AD7501KN of its controller has malfunctioned. This IC is related to...
85
Hello everyone, I am a student and would like to take the next step and learn FactoryTalk (Batch preferably) and how to create HMIs etc. Would...
495
