Fire Sensor for Hydraulic System
One of the guys here worked on those big systems. He says that if the oil vaporizes enough the nozzel (or hole) will create enough static to light it up.
Must be exciting, his eys got big around as he was describing one that he witnessed.
leitmotif said:
With respect to ruptures they leave to avoid getting wet with oil or not breathing oil mist.
Having been through more than my fair share of hydraulic oil showers, I can attest to that. Everyone starts running.
I remember once when we were starting up a new 350HP platform several years ago. One of the connections off an 8" header had been made up but not tightened. Bubba saw it and, being the considerate guy that he is, took off running without saying anything. Seconds later the joint cut loose. Three of us, myself included, got completely hosed - there was a oil-fee silouete on the oil coverd behind me. The oil ran down behind my safety glasses and I couldn't see a thing - I had to be led to a sink.
Peter, I think you know Krug - sometime ask him about the time he drove home naked. (He had a brand new car and he was completely soaked front and back, so he stripped in the parking lot and drove home.
leitmotif said:
With respect to "normal" hydraulic system leaks - people ignore them all the time.
:oops: .... you mean the rags on the floor is not enough?? or "we have more cat litter, should I pour more on it?" :)
We hve had an injection Mold machine burn up here. One of the hoses for the nozzle shut off valve developed a pin hole and sprayed a heater band on the barrel. This fire got out of control in a matter of minutes. At that time we did not have a fire supression system so we thru the main on the switch gear and ran. Now we have heat sensors in a hood over the barrrels of our machines that will kill all power to the machine. We have our trips disconnecting the main feed for machine. This way all power is removed so secondary ignition sources are elimated. Downside is we sometimes have plstic flame up. Cold start ups are notorious for this.
In my opinion this is a very rare occurance. Also the machine was over 20 years old when it went up in flames.
Alaric,
I had to do something similar for our FM agent on some hot oil systems. I just used a heat detector mounted approx. 6' above the unit. It would shut the unit down if it went off.
It carries an FM approval.
New to the ABpoint IO and have some experience with plcs but not that much. Anyway my question is why are these output cards flashing red? I am...
1,153
Hi Can anyone give us the name and part number of programming cable for AM1000 fire and gas panel. Thanks
1,022
I am using studio 5000 for the program. For some reason even when the ladder logic is completely true to fire the output, the output still will...
26
6,604
We are thing about installing temperature sensors in the area of some of our large hydraulic systems These sensors would monitor the temperatures...
3,528
Hi guys I'm working on this project: There's a Fire Alarm system installed in a plant that we want to communicate with using a CompactLogix L32E...
2,493
