Firmware bug in AutomationDirect Stage Programming
zmanvortex
Apr 2002
Nebraska
216
Ok, to me this would be considered a firmware bug. I use stage and block programming heavily in my programs. I always assumed all stage bits in a block would be deactivated when the block becomes deactivated. This is true for regular stages (SG) in the block, but it does not reset any Convergent stages (CV) that are active in the block. I ran into this problem when I was waiting for two different process to complete. If only one of the process completed and was waiting in a CV stage, and someone hit an estop which would kill the block, then the CV stage bit would stay on. The only way to reset the CV stage bit was to cycle the power or try to complete the process again. The second method of resetting the stage bit could be disasterous because the program would think the first process is complete. The workaround I did in my programs is to add a rung below the rung where my bcall is and reset all cv stages in that block if the block bit is false. Has anyone else ran into this?
Hi all I have tried setting up the adc on a existing pf755 with studio 32 And want the firmware to update too the firmware on the plc is 12.01...
37
Good day all! Can someone help me with the procedure to update Beijers E700 firmware? The Panel I am working on is firmware 2.04v and I would...
94
Hi I was wondering I need to update the firmware of a 755 inverter does the drive hold the program on the drive and just updates the firmware or...
192
I have a 1769-L24ER-BB1B and I am trying to flash it to 34xx, its flashing red and faulted, when I try to flash it I get a popup stating it needs...
273
Hello, I have a 1764 1500 LSP Series A that keeps failing with DTL_E_FAIL I/O error. Searching around it seems there's a weird issue specifically...
121
