Addohm
So this is a first time I've had no choice but to use Flex I/O with anything RSLogix 5000. I've got everything up and running, but the values I am seeing are definitely not representative of the real temperatures I should be seeing. Has anyone set up a system with this combination before that could give me some advice? I have 26 thermocouples I am reading temperatures from on an extruder. At room temperature I see about 33 degrees, which if it was celcius would be pretty damn accurate. The problem is that I have the input set as Fahrenheit so I am not sure it's really an issue of units. I can see the values raise and lower with applied heat to the TC. Any suggestions would be appreciated...
Thanks in advance.
Thanks in advance.
