FLEX I/O Tag Syntax into Wonderware
Ones_Zeros
Feb 2014
at work
367
Hello
I'm trying to communicate to a PLC that has a FLEX I/O
from Wonderware. I can go online with the PLC (1769-L32E) and see the data coming in. but for some reason I cannot read this tag in wonderware.
here is the tag for example (Tag_New:0:I.Ch0Data) thats on the Flex IO
This tag is created in the controller tag section in the PLC
I created the Driver in SMC in wonderware as
-DASABCIP
-ENB_FLX (Host Name=IP address of Flex I/O)
-Backplane_FLX
-Logix_FLX
Can you guide me to what the correct tag syntax is in wonderware to read from the PLC?
Also should the IP in the SMC configuration be for the Main PLC or the FLEX I/O IP address?
What exact version of Wonderware's ABDASCIP are you using ?
It's possible that it can't handle tags with colons in them or requires specific syntax to handle them.
A colon separator character is typical of a Module-defined tag or a Program-scope tag in ControlLogix, and is typical of a PLC/SLC type data table register in the PLC/SLC/MicroLogix.
In general, I recommend against directly reading I/O tags from an HMI. We get a lot of posts we get where somebody discovers that their HMI doesn't support an IO-data-specific syntax or offset because it was designed to talk to ordinary memory tags or memory registers.
I couldn't see the forest for the trees there.
Mike's advice is exactly right; The main issue is that the IP address that Wonderware was pointed to was the I/O adapter, not the CPU.
Don't mistake the fact that FLEX I/O is in use for the FlexLogix CPU; that's an obsolete and short lived variant of the ControlLogix family that used 1794 I/O directly.
Modern CompactLogix and ControlLogix can use FLEX for I/O, but the 1794-AENT is just an I/O adapter.
I cant seem to find an answer in any manual so maybe you all can help. What is the difference between these two input tags on a PF 755? On a PF...
2,592
Hi all, I need to interface AB power flex 40 VFD with one third party HMI. I had look on the internet for AB Modbus Registers list & i...
2,182
Hello Friends First of all Wish all of you a Happy Holi. I have a confusion regarding the tag generated when i added the Add-On Profile of...
3,047
Hi All, I want to know PowerFlex tag stucture. I have question regarding this. 1) Like in Control Logix we can define/Create Tags. Can we...
4,452
I have a current program where we are monitoring the Amps on a motor, Output Current parameter 3, however it's actually linked to parameter 4...
2,765
