Flex IO 1794-OF8IH setup examples, 8 ch HART analog output, similar to OE4??
rollex
Mar 2014
Australia
55
I have been tasked with adding 2 analog outputs via flex IO to a SLC 5/05, the SLC currently has the following IO via a 1747-SN remote IO scanner
Rack 0
1794-OB16
1794-OB16
1794-IB16
1794-IB16
1794-IB16
1794-IB16
1794-IB16
1794-OE4
All of rack 0 is addressed via the I: file
Rack 1
1794-IE8
1794-IE8
1794-IE8
all of rack 1 is addressed via block transfers as per the manual
Now for some reason the engineer has specified a new 1794-OF8IH (8 ch HART analog output) even though we only need two more analog outputs and definitely do not need HART.
Would it be simpler if we replaced the OF8IH with an OE4 ??
Here is the flex IO manual which has examples for the IE8 and OE4
http://literature.rockwellautomation.com/idc/groups/literature/documents/um/1794-um002_-en-p.pdf
Here is the manual for the OF8IH
http://pdf.datasheetarchive.com/indexerfiles/Datasheets-SW3/DSASW0053043.pdf
Now the OF8IH manual has no code examples and I am unsure how to set it up with spending lots of time reading through it and comparing the two modules, would the code examples for the OE4 work, if not can someone get me started, unfortunately I do not have the card here and cannot test until we have a 2 day shutdown, would it be safer to swap the card for an OE4 ?
Any help would be MUCH appreciated! :)
I think he wants to know who the engineer was that specified the 1794-OF8IH. And blimey you are up late isn't it time for fourty winks mate.
I'm in Australia, the engineer probably picked the first card they found.
So any suggestions, I'm feeling a bit out of my depth especially with no hardware to test with.
Turns out this card is not compatible with the rack and have reissued a OF4I
We have a rockwell support contract so I've asked them to supply some code examples.
Has anyone else here written code examples for the block transfer for an OF4I?
Hi all, what is the proper way to fuse 1794-IE12 modules? fuse sizes/locations? We are burning up these modules in our facility.
1,725
Does anyone have any insite to when the 1794 Flex io will go active mature? Just not ready to switch to the new flex 5000. We use flex for remote...
1,608
Hey guys, Im currently using the above flex IO to turn on two outputs these outputs go to two flashing red beacon lights. Here's the scenario: My...
1,707
Anybody can help me. I already read document in software rslogix 5000 and I think i can use software rslogix 5000 calibrate for flex module...
1,737
This is going to be long winded just because i am going to try and provide as much info as possible. Over the last month i have had the...
2,414
