Flex logix 5434
Nishanth
Oct 2012
asia
Friends,
I have a problem with AB PLc .Its showing flashing red led on Local2 and green flashing led on local,also I/O is showing off.Can any one tell me how to solve the problem
Does the physical I/O match what is in the configuration? Do out have a second chassis setup in the configuration? I setup a Flex logic years ago and haven't seen one since then. I think they where short lived.
Actually this problem occured after changing the Old battery showing flashing red at battery with a New battery.The led at battery is off .But the problem is still there.
It's probably because the FlexLogix CPU has lost the application file when the battery was replaced and the hardware configuration has been defaulted.
Do you have a copy of the application file?
Go Online with the CPU and download it.
Hello everyone! I have a control logix plc that is set up to communicate with 6 1794-asb flex i/o racks. Everything has worked good over...
514
Something i ran into that has me stumped, hopefully someone can explain. I have powerflex 70's connected to a L7 cpu using a 1788-en2dn. The...
1,394
hello i am trying to set the max frequency for the drive via rslogix 5000, but do not see that patameter in the rslogix 5000 drive paramerts? the...
328
Hello, I have an existing application that has a Powerflex 700 with a 20-COMM-E adapter controlled by a Micrologix 1100 via Ethernet. The setup...
1,205
Folks, Putting together a system utilizing a Control Logix Gen 8 (5580) PLC w/ the L83e CPU. I'll be connecting to 8 different FLEX-IO drops...
4,123
