FlexLogic 5424
gusterminator
Feb 2009
Thunder Bay
85
Hi guys, I have a flexlogic 5434 for home use. I'm curious if there is 3rd party software I can use to program it since I can't afford to buy RSLogic 5000 for playing at home.
Does anybody have a solution?
Gus
RSLogix 5000 is the only software that can program any Rockwell Automation CompactLogix, FlexLogix, DriveLogix, SoftLogix 5800 or ControlLogix controller.
In the "old days" twenty years ago the controller memory and instruction set was simple enough that companies like Taylor Software and ICOM made programming packages that were competitive with or better than the manufacturer's own PLC editors, but that's not the case with modern controllers.
Do you have logix at work? If so, just install it on your take-home laptop, and open it once a week at work to "Borrow" an activation and return it. After that, you only have to put up with the licensing nag box, which usually pops up behind the Logix window. Dismiss it and go on.
Excellent point; that's what I'll be doing this morning.
We have all of our licenses on a server computer now because virtually all of our work is done at our home site, connected up to the Internet and the internal network.
So this morning I've opened up both RSLogix 5000 and FTView Studio to let them get activated, and when I open up again onsite they'll go into Grace Period mode, and I'll have another 7 days to get connected again.
On the plus side it's a clear morning down here in the river valley and when we say "the Mountain is out", it means we're looking up at one of the most majestic volcanoes in North America. Humbling, really.
I could do with a little help understanding how the addresses are linked. I'm having to check and probably modify an existing system which is...
2,984
Hello All, I am trying to connect my laptop to a PV 600 part number 2711-T6C5L1. I have a NET-AIC module, Flexlogic PLC and the PIC driver...
4,120
Hello All, I have two Flexlogic Processors. Both have an ethernet card installed in slot one of the expansion slots. I am trying to set a MSG...
2,837
hoi; I have a problem whith reading a Tage from a PLC (AB-Flexlogix). using the ethernet/ip protocol. the message that i send to the plc is an...
4,158
