Good start. Do you have access to a Micrologix 1000 PLC?
Yes, I bought the trainer, with 4- I/O
Greetings dronai ...
quick question: do you just want to "see" a flip/flop in action? - or do you want to really "understand" what's going on under the hood? ...
http://www.plctalk.net/qanda/showthread.php?p=427567&postcount=1
warning! ... this lesson uses 346 lines of text to describe (in gruesome detail) the operation of one "simple" rung ...
party on ...
the link I posted has two attachments ... I recommend that you print out the (JPG) picture of the rung – and then refer to that as you read step-by-step through the (PDF) description attachment ...
the main thrust of the lesson is to understand how the PLC processor interprets – and controls – its Inputs and Outputs scan by scan by scan by scan ...
many students have a problem "thinking through" the scan sequence – and they try to force the processor's action to fit into their own preconceived idea of how it SHOULD work ...
big picture idea: it's based on LOGIC – it's NOT electricity ...
you personally might have no problem with that critical concept ... I can assure you that other people (some with years of experience) have serious misconceptions about what's going on inside the processor ...
My Alternator program probably won't run then, if you do not have the full 16 In and 16 Out. You could modify it to only use the I/O that you do have (probably by deleting about the last 7 rungs).Yes, I bought the trainer, with 4- I/O
What is the actual model of the Micrologix that is installed in the Trainer?
You mentioned simulating 3-way light switches. Here is a Micrologix program that does it with only two inputs and 1 output.
Thanks, Mark.
What I was getting at, that since Dronai has electrical wiring expericence, he might want to use the two unused extra Inputs on the Micrologix1000 model 1761-L10B.
Hi Lance, he bought this one http://cgi.ebay.com/250401843406
4 in and 4 out (1761-L10BXB)
Hello dronai,
Hope you like the trainer.... see below for the one I like to use
I know a lot of people don't link to use counters but IF you don't mind see below
Download this... make it exactly this way
Then push the green button again and again
