Floboss 103 changing gas composition
ChrisMartin
Apr 2015
Vancouver
I have a Modicon M340 plc/ Magelis HMI and a Floboss that I'm wondering if there is a communication protocol to be able to change the gas composition through my HMI as we are switching between two systems. Not sure if this is possible but any information would be helpful. Thanks
the magelis HMIs I've dealt with were too basic it would be a pain in the ***. but new touch screen HMIs make it much easier. the FB 103 supports rs232 and rs485. Iy haven't personally.set this up.but I know it is possible and has be done successfully.
I don't know about the Magelis, but the Red Lion people now have the ROC natively talking to their displays (TLP's). Maybe worth a shot to see if it can be done in an easier fashion. Ask your local distributor for a try before you for buy with a G306 or Kadet model? o_O
I don't have much experience with a FloBoss107, but I was hoping someone could confirm some details for me. I understand that out of the box a...
943
I am looking to change a PID loop operation on a ROC Floboss 103. The valve is fail open. they need it to fail close now. Do I need to make the...
1,969
Hello everybody. This forum helped me many times, is the first time I make a post here. My problem: I have a floboss 407 (Link to download backup...
3,132
I need to be able to retrieve data from an Emerson Floboss 107. I've never done this, and it is probably the only time I'll have to. I could spend...
3,237
Hi Guys, I am going to be using a Floboss 107 and tie in a couple of turbine meters. I looked at the wiring diagram for PULSE inputs in the...
2,659
