widelto
My customer wants to add a DC controlled servo valve (0-10 VDC) to an existing and working flying cutoff (steel pipe mill), nowadays saw is move by a hydraulic cylinder that is driven by a two solenoid valve (Fwd/Rev).
We are using movable limit switch to signalize home end extended positions for the cylinder.
Customer installed a temposonic feedback unit inside the hydraulic cylinder (0-10 VDC).
They also provided us analog modules 1756-OF4 and a 1756-IF4 to be used as drive por servovalve and feedback respectively.
I would prefer to use 1756-HYD02 board, but i have no choice.
We are using a controllogix CPU processor & Rslogix 5000 V19.
Is there a way to include those boards as part of my motion group ??
Or do you have a technique to move cylinder back&forth other that using move instruction.
Is PID an option ?, I think standard PID is too slow to drive and control this servo valve.
