Fp Sigma/minas-s Problem
230grain
Aug 2007
NJ
36
I now have a small FPWIN PRO issue using the FPG_INC motion function. I thought if I put negative value in the “DISTANCE IN PULSE” it would rotate the motor in the opposite direction from a positive value. I made a test program where the done bit from the first FPG_INC starts a second move. The DISTANCE IN PULSE in the second move is a negative value yet the motor still rotates CW.
Output Y 0 is on during the first move and during the second move both Y0 and Y1 are on. I thought only Y1 would be on then. Is this normal?
I did find Parameter 41 in the amplifier manual that inverts the PULS & SIGN signals. It looks to me that setting Parameter 41 to “2” will invert the SIGN pulses Y1 and leave the leave the PULS pulses Y0 alone. Is this what I must do to have the rotation switch from CW to CCW?
Good Evening Everyone, I have a servo question. With a master slave setup, one motor was going into overload. I found this pretty quickly as the...
784
This is a little OT but I'm looking for anyone with experience with the Yaskawa Sigma 5 servo drives. We've had some servo drive and motor...
3,543
Morning all. I am currently using a FP-Sigma PLC from Panasonic. The first time I have ever used a Sigma before and I am running into an issue I...
1,276
I have a Panasonic FPΣ PLC that has register values that have changed, how do you read them and update your program. If you try to upload the...
2,788
hi, i have to do this program... my sensor sensed five times, the counter have to show "5" but the CT in this PLC can only count down.. and if i...
1,318
