FPWIN PRO7 REAL to DINT conversion not working
Try creating a tag with an address way above what are being used i.e. DDT400 (assuming none in that range are being used
& see if that gives you a reading.
also, check the compiler section as there are areas allocated to certain uses i.e. globals, internal use. compiler (for automatically assigning PLC variables on the fly used for temps as local variables during compile)
Make sure your DDT200 is well inside the range for global variables.
Solved
Thank you very much for your input everyone, turns out the DT102 shown on my declaration screenshot was interfering with the DDT200 registry. Found this through trial and error after your recommendations so decided to move that variable to another registry and IT WORKS AS INTENDED!
I don't see how a register in the 100's can affect one in the 200's perhaps there is some indirect addressing somewhere for example DT150[DT20] if the value in DT20 was 50 then it would point to DT200 thus possibly overwriting the DT200.
I'm writing some alterations to an FPWin program and need to see the running value of timers so I can set them correctly. It's my first time with...
134
I have an older (2006) Panasonic FP-X C14R that i need to connect to. I have zero experience with Panasonic PLC's and the FPWIN Pro7 software...
2,327
I can't connect to a FP2-C1 PLC using FPWIN PRO7 demo version, I've got a RS232 cable connected and a RS232 to usb adapter going into my computer...
1,386
I have been getting errors lately when trying to compile my program onto my FP0R32. I am using their ladder logic. The error is Not enough WR...
2,099
Can someone tell me what I'm seeing here? I'm online with the FP2 and looking at some rungs with DT120 and DT124. Each are used twice and each...
1,736
