Frequency meter
leitmotif
Nov 2004
Seattle Wa. USA
3,680
I need a frequency meter that can do the following
Be able to hook directly to 0 to 120 VAC
Able to measure from 0 to 120 Hz.
Here are two applications
recently trouble shot a home generator 4000 W 120/240 single phase. Freq meter would have been nice but used tach instead. Adjusted governor to better control engine speed.
Am setting up what may be a demonstration rig for variable AC drive. Will consist of motor (variable speed probably DC cause I have one) driving an automotive alternator modified to manually control excitation. Also took out rectifiers and brought out 3 phase. Alternator power will feed to either
A -- lite bulbs to demonstrate 3 phase by slowing alternator down to say one half Hz so that the waveform can be visualized on 3 lite bulbs. Got idea from synch lamps on switchgear - works well. Have done with VFD and 3 lite bulbs works quite well.
B -- another automotive alternator again with manual excitation control and with rectifiers removed. Will be used as synchronous motor.
Because this will be in a class setting an analog meter may be better because you can see oscillations in the meter needle.
Not sure if all this will really work so want to keep cost low AND just got my second social security check. So am watching budget pretty tightly. Lets out Fluke VOM which would be NICE.
Budget can probably handle $50 or so.
Thanks for help
Dan Bentler
To answer your question 1
I believe most good multimeters have a Hz setting available that would handle your voltage, I know most of the Fluke meters have that option.
Dial Hz meters are probably better sourced from electrical suppliers who should have a range of meters , what I have seen on Generators often work on a bar the acts as a tuning forkond vibrates one segment at the frequency found.
This is not as simple as I thought.
Panel instruments range 45 to 75
Fluke has no options - even DMMs respond no lower than 15 Hz they say.
Seems bottom end of almost anything for this application is 15 Hz.
Have found one unit but oh boy does it look pricy.
http://www.ectron.com/frequency.php
Am checking with local instrument outfit Branom - in Seattle.
IF nothing else works out can always go the proximity sensor or encoder and convert pulses to frequency - just a little measuring and math.
Hmmm maybe should make this learning opportunity - never worked with encoder.
thanks for ideas and help
Merry Christmas to all of us
Dan Bentler
Gentlemen
Thank you all for the help. I believe I have enough options to look at so let us close this out and save you some work. Will advise on how I make out.
Dan Bentler
hello i am trying to set the max frequency for the drive via rslogix 5000, but do not see that patameter in the rslogix 5000 drive paramerts? the...
328
Hello, please its possible to control flow rate using frequency mode of a flow meter ? if yes, how is it done for a PLC like Micrologix ? i...
2,228
Do you folks know of any Motor Frequency Meters that have a 4-20 ma output ? I know a frequency drive would provide that need , but the customer...
2,510
Hello, Im trying to measure the frequency (Hz) of a fast input. what Im doing now is copying the Acc Count twice a second apart and subtracting...
2,871
Hello guys, I am new to this forum and have some problems with my PowerFlex755 EENET frequency inverter. I want to do a point to point...
418
