Frequent Motor Starting
go to http://www.sew-eurodrive.com/ this is one supplier
worth talking to. there are others
I laughed so hard.
We're doing a very similar thing in a packing machine for a main transport index. Sew-Eurodrive Movidrive B (MDX61B) servo drives, running an SEW-Eurodrive CMP series servomotor with resolver. It's a fairly inexpensive way to get something decent off the ground and will happily support either Digital I/O or Feildbus. The 2 we use are CanOpen (Built into the drive) or Ethernet/IP with Allen Bradley controllers (DFE33B card).
It's cheap and easy, why bother stuffing around trying to make something else work?
I have been involved with an Identical system JEEV
and it is cheaper and earier to use the servo.
I used the VSD method many times in the past, but now, there is no direct comparison.
The extra connections, wiring, mounting parts, programming etc. makes a servo so much cheaper.
Hi, I have a 1hp 3 phase 220 volt motor on a fixture with a very light load that is required to reverse very frequently. It is required to run...
20
5,988
Hi all, I'm dealing with an application that, even though it is not sophisticated, is new for me. Excuse my ignorance!!! I have an exiting...
4,540
Happy New Year , We have a number of Powerflex 4's and 40's throughout our plant. We have had a outrageous number of these drives fail the...
18
6,140
I've got a question, maybe an issue, but more just curiosity. I have an air compressor, 100HP, that runs with VFD contorls. It is the only one...
35
9,665
I am updating a machine first commissioned in 1998 with a FANUC 90/30 plc From hours of study, it appears that the original logic documentation...
25
4,695
