Frequent start/stop, conveyor.
I have a similar application; except power is much higher. Rockwell Kenitx 5500 system; 440V 23A.
It will depend on the acceleration and deceleration rates you need; but this type of application is exactly what servo motors are great at.
Controlled speed, acceleration and jerk rate. Also control for slop (backlash) in the mechanical components with an appropriately placed encoder. Precision positioning.
My application
average run time ~2.5s
average stop time ~0.8s
max speed 920mm/s
max accel rate 5000mm/s^2
max jerk is a calculated value from the inertia measurements during setup.
Thank you for sharing your experience!
Do you have any problems with overheating?
Elcan Sorry about the vacuum clutch that was about 30 years ago and I just did a search I didn't find anything either they may not be available anymore.
I would change the drive to an AC vector drive with a black max motor the should be fast enough for your application over size the drive a little over size to handle the heat.
Happy New Year , We have a number of Powerflex 4's and 40's throughout our plant. We have had a outrageous number of these drives fail the...
18
6,143
I've got a question, maybe an issue, but more just curiosity. I have an air compressor, 100HP, that runs with VFD contorls. It is the only one...
35
9,671
Hi, I have a 1hp 3 phase 220 volt motor on a fixture with a very light load that is required to reverse very frequently. It is required to run...
20
5,992
I am updating a machine first commissioned in 1998 with a FANUC 90/30 plc From hours of study, it appears that the original logic documentation...
25
4,699
I'm looking at a project where a cleated conveyor (chains on either side connected by a metal cleat with product between the chains being pushed...
7,108
