FS Gateway communication failed with FT Gateway
Apr 2011
Manila, Philippines
295
Hi Guys,
I'm facing a huge problem now. I hope someone had already encountered this problem 🤞🏻 .
So here's the set up:
-Wonderware will get the data from FactoryTalkView via FSGateway.
-in order for Factory Talk view to give data we used Factorytalk Gateway.
-Wonderware is for "read only" purpose
-We have 2 Workstations
> OWS 1 for Wonderware, FSGateway was installed here.
> OWS 2 for FactoryTalk View, Factory Talk was installed here.
I set up the FS Gateway, set Factory Talk Gateway as an OPC server.
Now, I got this -/W status which means a failure to read. I already set the DCOM settings of FTGateway to "none"
Is there something I miss? specially in device settings since I have a remote Server.
Thank you very much Guys.
God Bless
Hi Guys, I'm facing a huge problem now. I hope someone had already encountered this problem 🤞🏻 . So here's the set up...
2,582
Hi, We are trying to communicate GE CPE305 PLC (over modbus TCP) with the Siemens drive (Profibus) using Anybus AB7629 module which is Profibus...
1,947
Currently OPC Client (PI OPC Interface from OSISOFT) is reading the data from RSLinx Gateway which is installed on different PC. And we are...
7,041
I have an application where I am trying to communicate from GE 90-70 PLC using the IC697CMM711 module to an FES COMNET Gateway. I have proven the...
16,056
I have an application where I am trying to communicate from an Allen-Bradley SLC 5/05 using the DF1 port to an FES Gateway. We have 3 compressors...
2,678
