FT Studio SE alarm acknowledge button
chadhoot78
Mar 2010
louisiana
34
First of thanks to all those who reply to my many questions. I have successfully built an alarm screen and brought in several audible alarms to a poorly designed water treatment system in a new powerplant. Having no experience at all with HMI programming in FT Studio SE, it went quite well. My next question is this: My alarm acknowledge button in the HMI is a momentary Pb with the release action of acknowledgeall. I want to use that same button to unlatch a bit in the plc to also clear a flashing stacklight with a siren. I can do this with 2 separate buttons, but I need it operator proof. Since the button is not an HMI tag (just sends a command) how would I go about doing this? I made a HMI tag ALM_ACK, (referenced to a controllogix tag), and assigned it to alarm ack in the alarm tag editor. It did unlatch my siren and light, but had to press it several times in the Runtime to actually acknowledge the alarm.
sounds like timing.. you should latch a bit for a second in the plc when the ALM_ACK bit is pushed. Just hold it for a short time and unlatch it.
Hello, I made a change in alarm setup in factory view studio, where I changed a alarm message text. After that I made a run application and...
136
I am trying to enable an external alarm via computer speakers for Factory Talk Network Distributed Edition. I am using Alarm and Events setup. I...
177
Hello all. Is there a way to upload alarm tags at the bit level to my FTView studio? I export them from my PLC thinking I will upload them to...
411
Hello All. I am new to automation so please excuse my explanation. I am working on a request where I need to reset 2 alarm bits (AlarmError1_Alarm...
1,472
Hi everyone, I'm new to the forum and new to automation too. I am currently using FT View Studio to create the HMI of a project and I have come...
2,013
