FT Studio Version 4 to current
Doylen
Dec 2007
Virginia
46
I searched in this site, asking same questions but couldn't locate an answer.
One of OEM installed machine has Version 4 PV+.
The touch screen is not working so we purchased new PV+ Firmware version 10.
I was able to upload the .MER file but it won't let me creating the project to my current version software, Version 10.
I believe I must have version 5.1 FT studio with 32bit Windows software.
Before I buy older laptop with Windows 7 32 bit, can someone confirm this is ONLY way to make this work?
OR, is there a person kind enough to convert this attached file to version 10 or make an archive file?
Either ways, thanks in advance!
I pulled it up in my old 32-bit VM and got this:
This runtime application file was saved in an older format that does not support conversion to a development application.
There are some partial workarounds. Start here:
https://www.plctalk.net/qanda/showthread.php?t=90205
This article also talks about it:
https://theautomationblog.com/how-to-edit-a-panelview-plus-viewme-mer-runtime-file
It refers to a few Rockwell tech notes but the one they refer to as publicly available has since been locked down to TechConnect only.
Tech note (access level: TechConnect):
https://rockwellautomation.custhelp.com/app/answers/answer_view/a_id/8913
See also (access level: TechConnect):
https://rockwellautomation.custhelp.com/app/answers/answer_view/a_id/44554
And (access level: TechConnect):
https://rockwellautomation.custhelp.com/app/answers/answer_view/a_id/63228
Your best bet is to track down the APA file if at all possible.
@joseph_e2
Thanks so much.
I've tried all links but still doesn't work.
I've gov windows 7 32bit laptop and installed version 5.0.
But it would not let me restore either.
Maybe Rockwell tech support person can convert it and create APA file.
Yeah, you can't convert it directly but have to jump through those hoops and it still won't bring everything in. What are the chances you can get the original APA file?
@joseph_e2
Thanks so much.
As I mentioned, the reason that it won't convert is because your MER is v3.2, the concept of restoring MER's didn't exist. In those older versions, you had to keep the APA file to restore. This isn't a matter of having a newer version to restore it, no versions can restore a 3.2 application, the MER structure doesn't contain everything needed to restore it.
I don't think restoring MER's came about until v5. So any MER made pre v5 cannot be restored using the application manager, you have to have the APA file.
There is a hacky way to get most of the application back, but not everything, which joseph_e2 linked.
Slim to none.
The OEM company asked me why waited this long to upgrade since it's installed back in 2010. lol for them and (me)
I Just created tech connect case and asked them to convert is for me.
I will wait for their response.
I downloaded v24 for studio 5000 but can’t find where the download manager put it! Any help? I’ve done it before but can’t remember. Thanks
399
I recall there was some issue with a Studio 5K version above v32 that I should avoid. I don't recall what it was but they jumped a major rev...
446
Good Evening , I have version 28 of Studio 5000 from a few years ago . If I got a new CompactLogix CPU , what is the lowest version of...
483
Hi, Im trying to install Studio 5000 V32. I've installed the previous version in order from v20 to v31. Whenever I run the setup file i got this...
1,409
Hi All, While building the offline project for CLX 5580 with 1756 Rack I/O, I noticed that there is a field for "Series" and "Version" for some...
711
