FT View ME gfx error
eeuler35thss
Aug 2019
Ohio
I have a few apps that I imported from a runtime file using the .med import, since it has the version 5.1 only having the never allow conversion issue. When i try to open a display in Studio I get the following error.
Graphics: Unable to open a ME Runtime Application graphics file C:\{file location}.gfx
I tried both the runtime .med import and the 7-zip import method and both methods don't import the graphics files correctly. Anyone know how to get around this issue?
Have you tried add component method. If you right click on Displays in the Explorer window you should see add component into application. Then navigate the GFX folder in any project and select .gfx you need
I have tried that. It comes up with the same error during the import. I can import any other gfx file except the ones from the 5.1 runtime. It also comes up with a DMM(9:1) Migration error
Have you exported the graphic file and tried using notepad or a XML editor to open. Maybe if you compare with one that works you may see the difference and be able to modified the never allow conversion. This is just a guess but maybe worth a try.
edit: you right click on the .gfx and use open with.
I have read both of those a while back. The Knowledgebase is if the flag is not already set, and without a techconnect contract Rockwell wont help in removing the flag. Seems odd you need a contract, since this is a glitch in the software.
Is it possible to edit a View SE GFX screen with VBA? I’m using VBA to move some objects on the screen in runtime and save their position into...
2,557
I have created graphic files for a project in RSview ME. I have to send the image files to a documentation company so that they can work on the...
9,425
Hello guys please I want experience with this I am currently working on a scada project using FTView SE and I have an Ethernet IP local area...
31
I have two identical machines running similar HMI projects, the only difference is one is done in FactoryTalk View Version 10 and the other is...
195
143
