FT View target mer file from v11 to v10
apahtba
Jun 2015
here
Can any one here help me convert my .mer file to target v10 or older? Please.
Have a host of questions, but dont want to go off topic just yet.
thanks as always.🔨
When you go to create the .mer select the version you want?
I don't have my laptop with me or I would screen shot it.
VAN, I believe he has a MER that is version 11 and needs it converted to v10 because he only has v10 software
Ah, my bad.
Isn't downloading software free if you have the license?
I only knew that because of reddit. I think a stand alone license gets you the version you purchased and earlier. You might be able to get an update within the first year. Not sure though, we have toolkits
Hello all, I am changing the target device IP directly on a Panelview1000, and every time power gets cycled it seems to "forget" the new target...
2,564
I am trying to set up the Target Viewer Utility for Quick Panel View and am able to connect to the HMI. It gives the following info when...
1,891
I just got RsView 4.0 I am trying to setup communications between a SLC 5/05 and a panelview plus 600, but I cant get the Target tab to show up...
1,830
I have two identical machines running similar HMI projects, the only difference is one is done in FactoryTalk View Version 10 and the other is...
154
137
