Shaquille_Oatmeal97
Hello all,
I am changing the target device IP directly on a Panelview1000, and every time power gets cycled it seems to "forget" the new target IP. The steps below are exactly what I have done.
1. Went to terminal settings
2.Selected Network and Communications
3. Selected RSLinx Enterprise Communications
4. Scrolled to the target device, and then selected Edit Device.
5.Changed the IP and then went back to the config screen.
6. Loaded the application and did not replace terminal communication settings with the applications.
The application works fine after I follow these steps, it is after I cycle power when the Panelview seems to lose the target IP.
Has anybody else had this issue?
Thanks,
Thanks,
