FT Viewpoint Issues
mjp123gp
Mar 2012
Savannah, GA
94
I've got a PVP1000 setup at my dads to run his sprinkler system and i've been using Viewpoint so he can access screens via wifi while out in the yard. A few weeks ago he started having issues with the viewpoint where is shows an error then a bunch of text. Nothing has changed on the system in over a year. Only thing I can think of is maybe iOS safari updates have caused the problem. Anyone seen this before? See screenshot.
Edit: Attached pic not working. Maybe this - https://imgur.com/wXxS4mn
I second harryting's comment - I thought my sprinkler system was impressive, but a PVP1000? Damn!
I don't have a lot of experience with ViewPoint, but like you my first suspicion would be iOS or Safariu updates. Have your dad download the firefox app and retry, or try different browsers from a PC on the same network, compare results.
I'm going to re-flash firmware and create a new runtime file to see if it helps. Panelview was actally free, I pieced it together from a few none working units. That was years ago though before they had all the wifi/mobile app enabled sprinkler controllers available.
Hi All 1.I used viewpoint administration to publish a screen to display on seperate 24" monitor through PC and google chrome. The issue i'm...
784
I want to use ViewPoint for a few machines so I can remotely monitor them and help with troubleshooting from home, etc. I cant get my alarms...
1,549
Hi all, I am facing some issues with the factorytalk viewpoint. I have this string tag in PLC which can be read from FTView SCADA. The display...
1,101
So, I want to view the Viewpoint on a Panelview+ that's connected to another, dedicated, network card on a Contrologix chassis. I asked Rockwell...
1,217
Is it possible to see on the HMI if anyone is using viewpoint. Maybe a registre I can read from the PLC. I need a light to go red, if someone is...
1,394
