FTME VM to RSLogix500 emulator VM communications
Bob O
May 2003
1,873
Is it possible to point a VM running FTME 8.1 to another VM running RSLogix5000 20.0x emulator to test screens both running on the same host machine? Hope that make sense.
Edit... VM software is VirtualBox
Thanks,
Bob O.
IIRC you have to change the FTView communications to look at an RSLinx OPC server.
Since you're running v20, I would suggest ditching Emulate and using SoftLogix instead. Your FTView communication setup would be the same as it it were a PLC. The downside is if your program directly references physical IO that will produce compile errors as changing to SoftLogix controller will wipe out the hardware tree. If you're one who maps IO, just delete the IO mapping and off you go.
Hi, Is that possible to log alarm history with FTVME and directly save as CSV, like how we doing in DataStore PLUS for DataLogging? Thanks, Dhimas
810
Hi Everyone, I'm converting from Panelbuilder 32 to FT ME. After importing I received this two errors: 1- Bit and LSBit triggered alarms that...
1,562
Anyone run into FTME 11 just locking up when you do a right click then tag search/replace on a screen? Task manager can’t kill it and I must...
1,534
Hi all. Is there a system word in FTME (5.10 & 6.0) that will allow the plc to interrogate for the current login level? I've looked in all (I...
1,568
Hi, This is hopefully a simple question. I have uploaded an application from an existing PV600+ that was developed in Version 5. I have Version...
1,448
