ftpget from ControlLogix?
JamesL
Mar 2014
Maine
18
Hi, me again. I've got my ControlLogix furnace running decent now, thanks to the folks here who've helped me along so far.
So, yes, a new question: at the end of my cycle I have a VB program that would reach back with rslinxpe to the PLC5 and grab all the stored alarm & machine data and move it to local txt files then sql load to oracle.
It would take a couple minutes, now it takes forever~ like 45 minutes for very short runs. (and actually typically times out/fails).
Below is some of the basic code (you can see I tried rem out the old ":%d" for [%d], no improvement).
I'm hoping there is a simple syntax issue that someone will recognize...
****some of the code below***
'*****Extract Alarm data from PLC******
'* open ftp connection to rslinxpe *'
conRet = Connect_To_Server("localhost", "user", "furnftp")
If bActiveSession = True Then
'* Issue Get command for all alarm data *'
'* Create alarm00.txt through alarm02.txt *'
For X = 0 To 1
tmpStr = Format(X, "00")
getRet = Get_Data("RAW/N7" & tmpStr & "[%d],0,1000", "alarm" & tmpStr & ".txt")
'was getRet = Get_Data("RAW/N7" & tmpStr & ":%d,0,1000", "alarm" & tmpStr & ".txt")
DoEvents
Next X
getRet = Get_Data("RAW/N702[%d],0,200", "alarm02.txt")
'was getRet = Get_Data("RAW/N702:%d,0,200", "alarm02.txt")
'* close ftp connection to driver *'
clsRet = Disc_Fr_Server
Else
blnConnect2Failed = True
End If
****end of some of the code above***
Maybe you can connect once when the VB app starts and only closes upon program termination:
this could improve things.
Or you could time some of the operations using the TickTimer:
tmrTiming= GetTickCount
<perform some operation here>
resultTime = GetTickCount - tmrTiming
this may help identify long winded operations ...
At the risk of sounding like an unhelpful newbie: what is "rslinxpe" ?
I'm familiar with using Visual Basic and RSLinx Classic, but I don't see any of the DDEInitiate or DDERequest commands I am accustomed to.
Cool, I'll look into that tomorrow and see if it helps. Thanks!
Now, now, I'M he newbie here. ; )
I thought initially that is was some compact rslinx add-on or standalone or something and someone would see a little syntax tweak I needed for the new clx plc... but now I think it might be a local/custom ftp server or something written by my predecessors for this datacollection/fetch task -
I didn't see much regarding this in Internet searches, sounds like not a common thing to use ftp to copy plc data to flat/txt files?
71
Why does the controllogix redundancy modules use a single mode fiber vs multimode fiber?
99
Hello, I have two 16 point input cards and 1 16 point output card showing module faulted on my IO tree in Logix Designer. The fault code is...
226
Hello, My associate and I are trying to sync up two ControlLogix racks (7-slot chassis) with identical modules. We are able to see the secondary...
211
Trying to setup a message read via Ethernet. I have the path setup as 1, 1, 2, 192.168.66.10 I get an error code 1, ext err 315. I am beating...
250
