FTV+ 6 HMI Tag Bit Level Address
ian.smith7
Aug 2002
UK
145
Hi All
I Have an App running on a FTV+ 6 screen. The program is developed on FTV Studio V7 & the runtime is compiled in V7.
Is there a way to address a HMI tag to Bit level from another HMI tag.
I am sure I saw this in one the many manuals but cant find the reference.
Block transfer of Push Buttons
HMI_PB_Tag
(Analog Type Integer, Min=0 Max=0, Scale=1 Offset=0, pointing at an Integer word in SLC500)
The Following is the Tag for the individual Push Button
(Type=Digital, Target=Device)
HMI_PB_Tag.0
HMI_PB_Tag/0
HMI_PB_Tag\0
When creating The PB Tag I use the browse button and navigate to the HMI folder containing the Block transfer word then manually add the .0 etc
but all I get is a Not found error at runtime
Is my syntax wrong?
Do I need to create a shortcut pointing back into the HMI?
cheers
ian
You can't get to the bit level of an HMI tag.
Create a new HMI tag using the SLC tag address
ex. [shortcut]N7:0.0
If you are only going to read from the tag, then you could use the below expression.
HMI_PB_Tag & 1
Thanks for the reply arlen
I have already reworked my program to use a direct tag reference but Im still struggling to get it working with the added complication of a parameter file.
Its a push button Input to the PLC, hopefully have another look today.
Ian
I have spent multiple hours looking for a solution for the following problem. I have an HMI application that is meant to be installed at 3...
1,207
Hello everyone, I am working in a platform and we installed FTV CLIENT SE V 12 IN ALL THE CLIENTS COMPUTERS, we have 6 clients and only 1 is not...
106
Hey all, First time poster... I'm trying to convert a PBA to FTV but keep running into the same error... "Failed to open project:" I've...
1,468
Hello, I have a question about FTV ME Station. I'm trying to change a CV number value on a PID popup display to show in reverse scale. Where...
1,492
Dear All Is possible to connect 22 PLC ML1400 with 1 HMI 12.1 inch type Panel View Plus working with Factory Talk View ME through TCP/IP and...
1,922
