ftview active x driving me nuts
simmo231
Mar 2011
newtown
Hi All,
trying to restore a runtime application that i have been reliably informed was created in version 10 ftview, i get the below error:-
unable to load activeX control for display s005_Recip_system. cause: ME program Launcher: newer file version of activeX control required.
seems straight forward so i tried the following,
ftview V10, same message
ftview v10 with latest patches , same message
ftview v11 same message.
ftview v11 with latest patches , same message
any help please ....
thanks
I've had a conversation with Rockwell about this, I couldn't get through to them.
You need to restore the application in the version that it was edited in (or newer), not the version that the MER was compiled for. If you still want to edit in an older version, you need to delete the Activex control in the newer version, re-compile for your version (10 or 11, it appears). Then you need to add the controls back into your copy. Rinse/repeat if it ever is edited in a newer version down the road.
Edit: In your post, you say that it was created in v10, while the MER may have been compiled for v10, that MER was generated > v10. Likely 12 or 13, since you could not restore it in 11 either.
I have a program that will have 20 parameter files for 1 page, and have 5 pages with 20 each. What i'm trying to figure out is how can i enable a...
2,064
Hi everybody. I wan to show a symbol in my displays when one or more alarm conditions exist in my FTView ME application (active alarms), but I...
1,934
Hi everyone! I have Panelview plus that is attached to a compactlogix controller, and I would like to use the built in alarms feature in view...
3,695
Hi All, Everytime I try to call the current object in FTview, I need use the coding below to call the property of the current active object...
2,498
I am creating a global object in FTView SE 13. I want to have a string read from the PLC and display (in this case the tagname). So lets say...
171
