FTView- Cognex InSight Display Control
It is installed as part of the Insight installer, I would recommend choosing to install the sample projects as well, very helpful for setting it up.
The controls themselves are usually located in C:\Program Files\Common Files\In-Sight\%version%
Thanks bro.
I found CvsInSightDisplay.ocx file and installed Display Control Sample project.
I faced another problem.
I run FactoryTalk View on my laptop which can see the barcode images.
I cant see the barcode image if I run on Panelview Plus 7(HMI).
Alert message that "unable to load ActiveX control for display"
The Cognex activex controls aren't installed on the Panelview.
Now, i'm not sure they CAN be, but you are probably going to need to reach out to Cognex and/or Rockwell to find out.
Offhand, I know that the Cognex VisionView software CAN be installed on a performance panelview 7, there's a knowledge base article I recall seeing once upon a time.
VisionView manual wrote that for Panelview 7 standard only.
Is it performance work as well?
I installed VisionView on the Panelview 7 performance but it alert message that "cant find an Entry Point 'StartDSSPDispatcher' in a PInvoke DLL 'CogPlatform.dll'."
In case anyone else still needs this, I was able to solve the "cant find an Entry Point 'StartDSSPDispatcher' in a PInvoke DLL 'CogPlatform.dll'." problem by using the x86 VisionView installer instead of the ARM.
Hi all, I am hoping someone may be able to point me in the right direction regarding setting up a cognex insight display control ActiveX into my...
2,287
I am creating a global object in FTView SE 13. I want to have a string read from the PLC and display (in this case the tagname). So lets say...
172
I want to set user security level based on the value of a tag in my PLC called "ActiveUser". That tag will contain the A-P code which we use for...
222
Hi All, we've recently upgraded from FTView SE v10 to v12. Since the upgrade we've been having a problem where the HMI is slow to update tags in...
92
Hi, I have an issue accessing tags in 3 of my plcs'. When I go to select a tag there is no folder drop down as can be seen in the photo. Any...
92
