Ftview display relative position
Revnus
Aug 2019
Brazil
73
In my FTView SE project I have a faceplate that have a button. By clicking at this button, the faceplate enlarges showing other options. I've tried unsuccessfully to show this enlarged faceplate at a relative position to the smaller one.
I know that there is parameter option to the display command "/RP" which shows the desired display near the position of the previous display. Problem is that "near" isn't enough.
I would like to specify the position of the enlarged display relative to the smaller display.
I've tried some commands like this: display enlarged_display /RP(-50,200), but the "(-50,200)" wont work.
Specifying a postion x,y at the display properties wont work either because the operator may want to drag and move the display in the screen, changing the original position.
What can I do?
Hello all. Many years ago I programmed an Omron PLC and HMI and I was able to control which display was being shown on the HMI from the PLC. Is...
338
Hello Every one, I need a help on vba code for getting data from MSSQL server 2014 to display in FTview SE client version 12 . Thanks. Please...
1,820
Hello PLC folks, I am using FTView Studio SE v10 in my project. I have 2 monitors and the headers are duplicated to be able to use on both...
3,597
Hello everyone, I'm getting some weird behavior from one of my displays in a FTView SE v11 application which has a total of 10 displays. The...
2,312
Hello, I have an FTView SE Network Distributed application in operation at my plant and the operators mentioned that one numeric display on a...
1,814
