FTView ME 6.1 Event track
CarloA
Oct 2019
canda
Hi all,
i am having trouble finding out how i could track an event like start command or stop command. is there anyway to do it in FTView ME 6.1 with PV Plus 700?
i am looking into the diagnotics but no luck,
i want to be able to log a change of state with the time it happened and who the user is at the time.
is this possible?
Hi all,
is this possible?
Look into the FTView ME datalog. Add the tags you want to track. I think you can also add the system\User tag which should tell you which user is logged in. Hope this helps.
I set up an alarm screen the trigger being what ever you want track, then set the alarms to show timem date and what ever you want the message to be.
Hi, I am having some issues with FactoryTalk View SE (Local) Alarm and Event server. In my "active" alarm windows all alarms is shown correctly...
968
I swear I had this working, but I'm on site deploying this and find it's not working. I have a string input, exposed to VBA, that has a Change...
2,608
Hi there, Is it possible to execute a VBA code using the 'Action' field in an event? Since FTView doesn't have the vbaexec command... If not, how...
5,374
Hey everyone, I'm in the process of building a panel view program to replace a OEM Citech HMI program. I'm down to the last screen which is an...
3,434
Hi all, I have a network distributed FTView SE system, which has three clients, showing alarms for three different sections of plant. I have...
4,454
