FTView string input VBA Change event
phuz
Jun 2008
Mohnton, PA
1,044
I swear I had this working, but I'm on site deploying this and find it's not working.
I have a string input, exposed to VBA, that has a Change event, but it's not working. I put a temporary MsgBox instruction which won't even execute.
FTView SE 8.2
Code:
Private Sub CanNumber_Change()
Dim FiberType As String
MsgBox ("test")
FiberType = Mid(CanNumber.Value, 6, 1)
Set oTag = MyGroup.Item("ERE_FIBER_TYPE")
If FiberType = "C" Then
oTag.Value = 0
ElseIf FiberType = "G" Then
oTag.Value = 1
ElseIf FiberType = "M" Then
oTag.Value = 2
ElseIf FiberType = "P" Then
oTag.Value = 3
ElseIf FiberType = "T" Then
oTag.Value = 4
ElseIf FiberType = "H" Then
    If Mid(CanNumber.Value, 6, 2) = "HH" Then
    oTag.Value = 6
    Else
    oTag.Value = 5
Else: MsgBox "Invalid Can Number!"
End If
End Sub
Error checking. Always include error checking. At least then you can log a diagnostic message to work out why all of your VBA stopped working :ROFLMAO:
I have found with FTView that firing off change events on string tags is at best 80% luck. Way back when, while trying to get it to function, I seem to remember that it only fired off of a change in the .LEN field, but I may be mistaken.
My solution has been to just add all the characters in the string to a DINT, and firing my change event off of the DINT tag.
Hi, does anyone know if there is a way to pre-fill the keyboard pop up used to input strings in FTview Studio ME? (v8.0) I have to allow...
2,248
I am creating a global object in FTView SE 13. I want to have a string read from the PLC and display (in this case the tagname). So lets say...
184
G'day all, I'm trying to set up interlock display in FTView (ME, but should apply to SE when I convert to that) in a manner which makes my...
2,596
Hey folks! I've gotten an idea in my head and I'm wondering if anyone can help - and my title is terrible because I'm not good at articulating...
1,039
Hi. I migrated panelbuilder32 hmi to factorytalk view. However character array is not supported in ftview. Appreciate your help how to map the plc...
1,763
