FTView ME Transfer Utility Error
rankhornjp
Dec 2008
Georgia
241
I have FTView Version 11 running on Windows 10 and I can't upload or download to any Panelview. I get the "Source selected is not a valid device" error. Most of the Panelviews are 6s or 7s and are running version 9 firmware. I have 20+ Panelviews and I can't upload/download from/to any of them, but I can see them in the list and in RSLinx and I can ping them.
I had this problem a few weeks ago after a Windows update. I upgraded the standalone Transfer Utility to version 12 and then installed the most recent patch rollup and have not had problems since.
One coworker reported the same issue, resolved the same way. Another has not had the issue at all.
Oh boy, I've been here. I've been meaning to make a video on how to solve this because it is easier showing than typing.
On your PanelView Plus, delete the RSLinx Enterprise setup (restore default). This will allow you to download again, after you fix your application, described below:
In your application, right click on FactoryTalk Linx and delete the server (one level above Communication Setup). Then right click on the 2nd item in the tree (it will have your application name) and add a new FTL server. Re-create your shortcut. Re-download your application.
I tried to get RA to add how to actually fix the application to their technote, which only describes how to temporarily "fix" the PanelView, to allow another download. If the application is not fixed, then you are in the same boat after the very next download.
Thank you! This fixed my issue.
You're welcome.
What dmroeder referenced can indeed cause that error, but that affects individual panels. With 20+ Panelviews all suddenly showing the same issue simultaneously, the cause is much more likely on the PC end.
You're welcome.
Solid point.
So I have FTVS ME 8.10 and I'm trying to upload PV+ programs over Eth/IP. I have an RSLinx Enterprise driver but I can't seem to make any changes...
2,807
I am creating a global object in FTView SE 13. I want to have a string read from the PLC and display (in this case the tagname). So lets say...
171
I want to set user security level based on the value of a tag in my PLC called "ActiveUser". That tag will contain the A-P code which we use for...
214
Hi All, we've recently upgraded from FTView SE v10 to v12. Since the upgrade we've been having a problem where the HMI is slow to update tags in...
89
Hi, I have an issue accessing tags in 3 of my plcs'. When I go to select a tag there is no folder drop down as can be seen in the photo. Any...
86
