ftview mer restore issue
mike_dr
Sep 2011
Mla
215
Im not sure what version was used but I cannot restore the mer file of ftview. I used 5,6,7(another pc) but not in 6.1. no apps open and using application manager, I select restore runtime application then select the mer file(tried putting in different locations), then input the name and press next. then I get the notepad error "system did not find file path not specified" and another popup "please check that there is sufficient disk space, that it is not open elsewhere, destination application does not exist already". the language is Japanese if that matters. apps are in VMware also.
Also tried the ver 4 process (run mer file then copy the ~mer file in temp folder then create new application and import med file) but the screens cannot be converted.
Restarting does not solve it. Does having a specific FTview patch affect it (if the dev pc has patch xx and I restore using another pc)? Can version 7 suppposedly restore a 6.1 mer file?
EDIT: put in the steps
Can you give a little more detail on what steps you're taking and at what point the errors appear? I'm not completely clear on what you're doing :)
Hmm. Well yes, that's an odd one. The only KB article I can find says that you can't do it from a network drive. But you say you've tried saving the file in other locations, and besides, I've done it off a network drive. So I'm not sure.
You could try repairing your FTServices, not that I really think it'll help. Or else post the file and I'll see if I can extract it, that'll at least tell you if it's the file or your setup
my issue now is that rslinx enterprise does not install in the 64 bit window 7 machine. In ftview 5.1, rslinx has a yellow question mark icon and I cannot install later version of rslinx enterprise since it the ft service platform needs to be upgraded.
I cannot install 6.0 in 64 bit since installer says doesnt support 64 bit.
I tried ftview 6.1 and the accompanying rslinx enterprise 5.4 in 64 bit window but I go back to the original restore problem of "path not specified".
is there any solution to this?
Keep in mind that my tool's ability to detect that architecture that the MER was created on is flawed. It sometimes reports 64 bit when it was in fact crated on a 32 bit machine. I haven't spent the time yet to find a better way to more reliably determine 32/64 bit.
I use FTview version 7 on Windows 7 64 bit and can restore any vintage of files with no problems (well, I haven't had any problems yet!). I have RSLinx enterprise v5.6, and FT Services platform 2.6
If you have the install files available, try upgrading everything to there and see if you have any luck?
FTView - cannot restore .mer "file is not a valid runtime application file." Hello Experts, I was given a .mer file and i cannot restore it...
7,473
Does FTView ME Station "Edit Device" Change MER File or Only Station Settings? I'm basically trying to permanently change an MER file's...
1,430
Hello all, I have FTView Studio v.12 and I have a PV+1000 that has v.5 FTView ME FW. When I create my .mer the earliest option it gives me is to...
4,570
Hello. I have a PV7, using FTViewStudio v.12. When I load the .mer I get "?" instead of text. I haven't had this happen to me before when it comes...
1,701
Hello, all! Maybe someone had the same problem? I use the Rockwell Automation software. I need to make 24 hours timer indicator with minutes on...
1,818
