FTView Studio v.12 question mark on .mer
ceilingwalker
Mar 2010
Phoenix, AZ
1,586
Hello. I have a PV7, using FTViewStudio v.12. When I load the .mer I get "?" instead of text. I haven't had this happen to me before when it comes to a simple label. For example, I created a shutdown object and labeled it "shutdown". My runtime file displays a "?" instead of the text from just the label. This is a new one for me. I have had it happen before whilst trying to display a numeric value from a tag before but not this. Thank you.
The question mark is shown because no text has been defined for the object. In my experience, this usually happens for one of two reasons.
  1. There is no text defined for the object. Based on what you've described, I'm guessing this isn't the issue.
  2. The runtime language doesn't match the development language.
With the second one, you would likely see the question marks on all objects with text. The first one would appear only on a single object.
Do you have text on other objects?
OG
Hello all. Many years ago I programmed an Omron PLC and HMI and I was able to control which display was being shown on the HMI from the PLC. Is...
338
Hello all. Been a while since I have had to load FTView SE and, for some reason, I am unable to find the "chat" button on the rockwell site...
2,808
Hello Experts, I am trying to create a SINE Wave generator and i cannot seem to make it smoother. I have done this before but i forgot the exact...
294
Hello all. Is there a way to upload alarm tags at the bit level to my FTView studio? I export them from my PLC thinking I will upload them to...
411
Hello all. I am trying to establish my connections in FTView Studio. Normally, after I have set up my offline tag file in communication setup I...
657
