FTView SE Studio activation issue
dwouters
Nov 2015
NH
I used FTview SE station 8.0 to develop an HMI project two years ago. Never had an activation issue.
I now have several more projects to do, and decided to move to FTView SE 9.0. I installed it in VMware so I could keep version 8.0 also for supporting the older project. I use the same activation dongle (green w LED) for both versions.
In 9.0, I get event messages first that the product has been successfully activated, a few seconds later that it has not been activated and is now in grace mode. When I open a project, I get a pop-up notice that my "HMI_SERVER" for this project is running in grace mode. For any VBA or screen with VBA I test, I get two "grace mode" pop-ups each time that I have to clear to proceed. It gets old really fast.
I contacted Rockwell support for this, talked to three different people, and the answer I get is that this is "expected behavior". They "corrected" something in the activation in V9.0 and this behavior reflects that.
I have a valid FTV SE Studio license, I do not want to get dragged down with grace mode messages while working in Studio. They said the only remedy is to also install a Station license on the same machine. I do not want that nor should I need it. In FTSE 8.0 everything works just fine.
Do others also get the grace mode messages? What did RA support tell you about this? Just want to know if this is a common issue and what people have done to fix it.
I was getting the same message earlier this week with a new install of FTView, using a dongle but not on a VM.
I reinstalled the HASP driver, downloaded the latest from the manufacturer. Fixed.
Hello Experts, I am trying to create a SINE Wave generator and i cannot seem to make it smoother. I have done this before but i forgot the exact...
316
Hello all. Is there a way to upload alarm tags at the bit level to my FTView studio? I export them from my PLC thinking I will upload them to...
425
Hello all. Many years ago I programmed an Omron PLC and HMI and I was able to control which display was being shown on the HMI from the PLC. Is...
351
Hello all. I am trying to establish my connections in FTView Studio. Normally, after I have set up my offline tag file in communication setup I...
664
Hello everyone, I had a problem that happening with FactoryTalk View Studio SE (V12) (Network Distributed). If i create a new project...
649
