FTView SE VBA TagGroup
adh2004plc
Dec 2011
duluth,mn
I am using ftview se 8.0. I am currently working to monitor tags and send their values along with some other information over to sql server on change. Before anyone asks I am using the data log model on a number of other tags but these particular tags and the information I am trying to get to sql dont fit with using a datalog model. I am running into an error that says Invalid procedure call or argument. I am guessing it has to do with what I am trying to pass as far as the TagNames.Item(i) is concerned.
My ultimate goal here is to track which tag has changed and what its value is so that I can pass that information to the SQLInsert subroutine to have it logged to sql. Any help would be greatly appreciated. Here is a copy of the subroutine that is causing my error.
Private Sub mtgDevice_Change(ByVal TagNames As IGOMStringList)
Dim i As Long
Dim UserID As String
Dim Message As String
Dim Device As String
For i = 0 To TagNames.Count - 1
lTime = formatLogTime(LogTime.Value)
Message = "N/A"
UserID = SysUser.Value
Call SQLInsert(lTime, Devices(i), CStr(TagNames.Item(i)), Message, UserID)
Next
End Sub
Code:
  Dim i As Long
  Dim [COLOR=Red][B]Device[/B][/COLOR] As String
    Message = "N/A"
    Call SQLInsert(lTime, [COLOR=Red][B]Devices[/B][/COLOR](i), CStr(TagNames.Item(i)), Message, UserID)
  Next
End Sub
Devices or Device?
Hi all. Currently I'm working on a VBa script for FTView. I would like to understand a bit better about some commands. 1) What are the...
609
Hi all. I'm running a VBA code on my FTView which is actually working, but everytime I open the display that calls the VBA code, it throws the...
28
1,839
Greetings, I have this question: How can I add a tag, in my case LS:0 {#5} (literal string of tag #5), to a variable using VBA? I couldn't find...
907
Hello Every one, I need a help on vba code for getting data from MSSQL server 2014 to display in FTview SE client version 12 . Thanks. Please...
1,833
I've been messing around with trying to find a way to clear all PlantPAx AOI latched alarms via the Alarm Banner or Summary objects. So far, I can...
1,746
