FTView SE - VBA to get quantity of alarms at banner
Revnus
Aug 2019
Brazil
73
Hi.
I'm trying to get the number of alarms from an alarm and event banner located on a display called "alarmepag1" and write to a HMI tag "AlmInAlm".
No success yet. How can I do it?
Here is the last code that I tried:
Dim ChangeAlarmVBA_int As Tag
Dim MyGroup As TagGroup
Dim bannerVBA As AlarmSummary
Option Explicit
Private Sub Display_AnimationStart()
On Error GoTo ErrHandler
Set MyGroup = Application.CreateTagGroup(Me.AreaName)
MyGroup.Add ("AlmInAlm")
Set ChangeAlarmVBA_int = MyGroup.Item("AlmInAlm")
Set bannerVBA = Me.Application.LoadedDisplays("alarmepag1").Elements("FactoryTalkAlarmandEventBanner1")
ChangeAlarmVBA_int.Value = bannerVBA.AlarmFaultCount
Exit Sub
ErrHandler:
Application.LogDiagnosticsMessage "Error occurred in " & ThisDisplay.FullName & _
" Display_AnimationStart(). Error # " & Err.Number & ": " & Err.Description, ftDiagSeverityError
End Sub
Hi all. Currently I'm working on a VBa script for FTView. I would like to understand a bit better about some commands. 1) What are the...
599
Hi all. I'm running a VBA code on my FTView which is actually working, but everytime I open the display that calls the VBA code, it throws the...
28
1,814
Greetings, I have this question: How can I add a tag, in my case LS:0 {#5} (literal string of tag #5), to a variable using VBA? I couldn't find...
897
Hello Every one, I need a help on vba code for getting data from MSSQL server 2014 to display in FTview SE client version 12 . Thanks. Please...
1,816
I've been messing around with trying to find a way to clear all PlantPAx AOI latched alarms via the Alarm Banner or Summary objects. So far, I can...
1,740
