FTVME HMI Tag problem
kevinc69
Sep 2017
Texas
I was about 9/10 done building a new HMI program using both HMI tags and direct reference tags. I was testing it to make sure all of the bugs were worked out of it when one of my screens locked up. I exit out of the application test and when I opened it up again, I quickly realized that all of my HMI tags had quit functioning, but the direct reference tags still worked. I checked the addressing on my HMI tags to make sure that they were still looking at the correct shortcut in linx and they were. I can replace an HMI tag with its direct reference and it will work, but that will take forever. Does anyone have any idea what might have caused this? Thanks in advance...
Your post suggests that the HMI tags were working prior to the crash, amirite?
In FactoryTalk land, if an application crashes, something will be broken and you will have to reboot your machine.
That is correct, I had tested my application several dozen times over the course of the build, and they were working....I tried rebooting.
OK, so this is Rockwell for you. I had left the application test open while I went to lunch, and when I came back, all is working again....
Hi, We don't do many Rockwell projects but recently did onw with a Control Logix and Panelview. What files do customers expect when you send...
263
So I have a PVP7 with keypad and a trend screen setup. I started fumbling around with buttons and managed to move the trend forward and backward...
942
I am trying to replace a Panelview Plus 600 from a machine. The HMI works it is just damaged on inside plastic and won't stay together. I uploaded...
1,305
While creating a runtime, the progress window shows: compression Tag\ABC1_ABC.db.wat The ABC1_ABC is a project\target\tag\???? from a previous...
1,554
Hello- I have a project where I have 3 buttons that write a value to a register (off/man/auto equals 0/1/2). I want the current mode to highlight...
1,726
