FTVS ME Alarm Trigger Error
JZerb
Oct 2016
Here
423
Im trying to setup some Alarms to trigger and display on the PVP at the same time. So i believe i set it up right in FTVS, but apparently i keep getting an Error and i have not a clue where it could be coming from. it reads "Cannot Interpret Area". i searched some and read it could be FTVS way of saying that there is a Syntax error with my direct reference tag setup, but i dont see what that could be. The only tag in the FTVS project is the one you can see here, [PLC]N7:0, im making sure i know how to get multiple alarms to trigger and display on a test environment before i go and try it on a larger project. ill let the pictures do the explaining, itll be better then me doing it myself.
not sure if restarting FTVS did it or rebooting my VM, but the Error message has since gone away. :confused:
Your alarm setup looks correct. Can you throw a numeric display on a display using the same N7:0 and see if it works? Use the tag browser, that's an easy way to know you are communicating correctly to the PLC. The activation shouldn't be an issue, however, the grace period is only 7 days.
I would like to change how a alarm display pops up. Right now when there is an alarm it is set to "replace". I dont want the alarm screen to pop...
2,223
Using Factory Talk View Studio, I am trying to set up alarms. I want set alarm triggers correctly and I am unsure if this is correct. I have a...
1,794
HI EVERYBODY How to see the list of alarms in HMI application created in FACTORY TALK VIEW STUDIO machine edition v6.1 . Thank you all
2,020
I'm trying to use a Numeric input enable to let users change their HMI password. The only problem is it deletes leading zeros when you enter it. I...
1,937
title says it all. at what point in time are ( ) required when writing expressions in FTVS? is it only when you want to 'look' at things it...
1,508
