title says it all. at what point in time are ( ) required when writing expressions in FTVS? is it only when you want to 'look' at things it groups.
ex. (tagA>2 and tagB>4) or (tagC<5 and tagD<8)
written as above tags A,B both need to be greater then 2 and 4 respectively OR tags C,D need to be less then 5 and 8 respectively. then the expression would evaluate as TRUE. what if the parentheses are removed, would it still look at the expression in the same manner?
