Function Blocks??
Schneider Modicon.
Also Can you tell how Modicon PLC addresses inputs that it wants to read through modbus.I know the command but Nobody is realy writing about the adressing format used?
inputvalue at %IW0:WORD;
in program you can make it real by WORD_TO_REAL
and then scale it according.
With a function block it is depending on what block you are using.
if you export the block i can tell you.
Modbus adressing are following :-
disrete :- 400001.0, 400001.1, 400001.2..
Analog:- 400001, 400002, 400003...
discrete outs 000001, 000002 etc (also for internal coils)
discrete ins 100001, 100002 etc
analog ins 300001, 300002 etc
analog outs 400001, 400002 etc (also used for internal registers)
These are standard addressing, unsure if anything different for function blocks, not used them.
Addressing for Modbus and Schneider plc (and probably other IEC based plc address schemes)
PLC input bit %I - not accessible via modbus
PLC output bit %Q - not accessible via modbus
PLC memory bit %M - read/write through modbus 10000 address range (with a 1 offset)
PLC memory word %MW - read/write through modbus 40000 address range (with a 1 offset)
PLC input register %IW - not accessible via modbus
PLC output register %QW - not accessible via modbus
PLC status bits %S - not accessible via modbus
PLC status words %SW - not accessible via modbus
Good morning crew! Ok my logic works but I am missing something. When the start button is pushed it should like the red light for 4sec then shut...
439
Hallo, I have Tia Portal V16 and I'm upgrading an older machine. That machine has a component running on rs232. The machine has still the old...
966
Hi Folks I have made a function block that has the EN input enabled. (FBD language) In want to run some code at the top of the function block as...
1,745
Hello. For a FactoryTalk View SE application, I recently upsized the PC monitor to a 46 inch. Now after changing the resolution to make...
1,172
Hi, I'm getting a bunch of these warnings when I build the program in Connected Components Workbench. The program is legacy code. The program...
2,398
