FX2n-32MT cpu problem
sttchui
Mar 2008
kl
81
i have two machine using same Mitsubishi PLC FX2n-32MT Series. One of those machine is down now, so i upload the program from another machine to a new FX2n-32MT CPU & replace the broken one.
After i replace it with new CPU none of the machine function work as it should be. So i try replace the broken PLC with the other existing machine CPU & it work as it suppose too.
I can't really understand why the new CPU doesn't work but the old CPU is working perfectly??? i just ONLY remove the old CPU & everything from wiring to termination is excatly the same as previous setting.
i also can see the expansion Digital signal is working & the Analogue input & output. But still i can't make it working in the new CPU
Have anyone experience this kind of problem before??? any help will appricciated.
Thank you!
Regards,
sttchui
cheak the data registers of hold type ,if some of them are not eaque to zero then set the data to the new plc's data registers of hold type.
My company received a machine with a Mitsubishi FX2N-32MT PLC AND A FX2N-2DA. I am not familiar with this model. It has been years since I have...
2,274
Hello all, I am looking for a Mitsubishi PLC programmer in the Knoxville, TN area. I need someone to upload the program from an FX2n-32MT and...
6,066
Dear all, I have fx2n plc on my hand but I don't have the programming cable sc-09 and it would not be easy for me to get one. I need the cable...
122
Dear all, what type of built in port does fx2n-80mr plc has? i mean is it rs232, r rs422 or rs485. and which module should i use to convert to...
126
Hello everyone, I am currently facing a challenge while trying to connect two Weintek HMI units with a Mitsubishi FX2N PLC. When connecting a...
566
