fx2n-4da to controle light??
avec21
Aug 2010
Netherlands
Hey guys,
I need some help with my school project.
We need to build a domotica system using a Mitsubischi FX2N PLC.
To dim the light were using a dc controlled dimmer ( 0-12V ).
Can someone tell me if i can connect the dimmer to a Mitsubischi fx2n-4da to set the light intensity?
And how can i controle the light intensity with citect scada?
Short answer: Yes you can.
Look up the specs on the 4da module, That's an analog output module. Does it have a suitable output range comparable to the Dimmer input?
Thats quick :D Thanks
The dimmer input range is 0 to 12 volt.
How can i control the analoge output with citect scada?
Thanks again
I have read the manual, but still i don't have a clue how to program the plc so they can communicate with each other.
Does anybody have some experience with the Fx2n-4da and GX IEC Developer 7.01.
For example which command do i need to use?
I have the FX2N-4DA analog output module and I am trying to send a value to one of the channels to give me a 0-10v output. Does anyone have any...
1,408
I’m a complete newbie with PLCs and electronics. I am trying to grasp why in the user’s guide section 5.2 Analog output range 0mA to + 20mA needs...
1,571
Hi Guys, I'm looking for a bit of assistance. I'm modifying an existing machine and need to use two 4da modules, I have the first on working as...
2,557
Hey guys, We're still busy with our school project ( even in summertime ) but were need some help. We need to dim a light using citect scada...
3,363
Dear all, I have fx2n plc on my hand but I don't have the programming cable sc-09 and it would not be easy for me to get one. I need the cable...
138
