FX2N more communication ports
Jirrr
Jan 2009
Czech
167
Hello,
It is possible to have more than two serial ports with FX2N...
in Programming port I have HMI and in added 485BD card I have embedded computer that works as a master on RS-485.....What I need is to connect another master/485 or 232 or if there is any different possibility/ and read some data from PLC.....It is possible to connect some other card to FXN CPU???
Thanks a lot...J
As far as I remember it can only have a serial port installed on the left side.
As well in the program there can be only one RS instruction to configure the single port.
Hello...
I do not need any RS instruction in CPU /or setting parameters/...I woud like to read and write some numbers from and to CPU using MT protokol which works without problems...but as I have both ports already used/both are "slave"/ I need 3rd port or to use some kind of arbitration which is not possible in my case...
One more question it is possible to use say RS and computer link/or parallel link and computer link/ at the same time???
Thanks...
Thanks a lot...this manual I did not have....
So these kind of communication are for additional sideinstalled port...
But is there any info about what protokols can be used with programming port if any?
No, Mitsubishi never published the protocol to read/write data through the programming port.
If you see some HMI from other brand communicating through the programming port for sure they use a protocol obtained through reverse engineering
Thanks a lot...
(By the way I have some HMI and also some PC scada connected using programming port....)
Have a nice day...
Dear all, I have fx2n plc on my hand but I don't have the programming cable sc-09 and it would not be easy for me to get one. I need the cable...
117
Dear all, what type of built in port does fx2n-80mr plc has? i mean is it rs232, r rs422 or rs485. and which module should i use to convert to...
119
Hello everyone, I am currently facing a challenge while trying to connect two Weintek HMI units with a Mitsubishi FX2N PLC. When connecting a...
559
Hello Im very new here with PLC world, i just buyed from amazon a FX2N-20MT, which I believe its a mitsubitshi clon, Im using gxworks2. Well my...
1,845
I've worked on one Mitsubishi PLC in the past 40 years. Now, it looks like I get to tackle another one...using GX-WORKS3-C1 software which I...
952
