adam_lhadi
i have the CU240E-2 PN unit
am documenting this PDF Converter with the CU240B-2 and CU240E-2 Control Units (siemens.com)
the problem i have is that when some parameters are mentioned like p1070 and p1071 and some other parameters ,i did not find them in Tia portal.
are they accessible only from the BOP !!
can you provide me with document which is easy to understand in order to master the G120 programing?
kind regards
kind regards
